Old 03-05-2009, 12:19 PM   #5
eightsandaces
Originally Posted by clb0099
Does any one have a DIY for this clutch switch?.. it worked once before then went to ****************..
It's worth the investment to buy a service manual, the Bentley book is a good one and should pay for itself if you plan on being involved with your own repairs. Having said that, the switch is quite easy to see on your back with your head under the pedals. As I said before, the plunger has what appears to be a ratcheting adjustment to fine tune actuation, if you're truly mechanical you might be able to restore operation of the current switch. If not, you can order one from a variety of sources, study the new part and glean what you can about how it's mounted and replaced, then carefully swap the two pieces, it should be fairly simple, good luck..
eightsandaces is offline   Reply With Quote
