Old 03-01-2009, 10:14 PM   #3
suburban99
If you clamp a small pair of vise grips on the spring clamp at the bottom of the bellows it will make the hose easier to remove as it holds pressure off the stock spring clamp. Leave the small vise grips attached when re-installing and the bellows hose will slide on easy, then remove the vise grips from below and spring clamp will hold again.
suburban99 is offline   Reply With Quote
