Old 02-20-2009, 04:02 PM   #15
ChrisZang
ChrisZang's Avatar
One more observation/caution:
I kept the Porsche OEM amp which was in the car (well actually it's a 6-channel amp from a 996, but otherwise it's identical). In any case: the level from the line outputs from the AVIC is not high enough to drive this amp, so the volume is kind of low. It's just loud enough in the highest volume setting. So I will need to install a Line Driver Signal Amplifier (a.k.a. "pre-amp").
This would not have been an issue had I bought the (more expensive) AVIC F90BT as this has 4 Volt line outputs
