Old 02-09-2009, 04:34 PM   #1
roadracer311
roadracer311's Avatar
My car had similar symptoms. I pulled my headlight switch, took it apart, filed the contacts with a points file (use for smoothing down ignition points on motorcycles) and put it back together. That was about 6 months ago and no problems since.
The switch is not intended to come apart. It wasn't easy to re-build.
Try pulling the fog lights on and then smacking it back in. If your headlights come on, then it's probably the headlight switch. The switch isn't that expensive, and as long as you're not re-building it yourself, it's pretty easy to swap out. (you'll need to find one of the DIY guides that have been posted here or on Renntech about switch replacement though, since there are one or two little tricks to getting it out.)
2003 Boxster S
1995 Ferrari F355 Spider
San Francisco, CA
roadracer311 is offline   Reply With Quote
