Old 02-09-2009, 08:10 AM   #2
green03
Originally Posted by vath2001
Join Renntech.org
But until you do, this is what I found:
P0171 Oxygen Sensing Adaptation, Idle Range, Bank 1 - Above Limit
P0174 Oxygen Sensing Adaptation, Idle Range, Bank 2 - Above Limit
Good luck
Thanks for researching Renntech; I'll join. The AutoZone guys read the codes as 'both banks running lean' and the most probable cause the MAF sensor. $285 later for a new MAF sensor and I still have the problem. Is it possible that the oxygen sensor on both banks would go bad simultaneously?
green03 is offline   Reply With Quote
