Thread: Stiff Shifter?
Old 01-13-2009, 10:16 AM   #1
Adam
Yes, definately pull up the boot and see if it has an aftermarket shifter in it. My guess is you do and it's not adjusted properly and there is too much tension on the bushings. As Tamarsha said the aftermarket shifters have an adjustment where you can put tension on the bushings whereas the stock shifter does not.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
