Old 12-31-2008, 08:41 AM   #18
jotoole
BURG BOXSTER
Quote "Know that if you have some short sockets w/ philips and torx bits, you can forgo putting the front up on jackstands and also forgo removing the wheels. It is helpful though to drive the front wheels up onto 2x6s for some extra clearance. Subsequently, if you don't put the front up on jackstands, you also don't have to pull the whole fender liner - just the 2 anchor pins . You also don't need to pull the similar anchor pins (from wheel well liner) on the body panel underneath. Once you loosen the 7 bolts/screws (they changed based on MY) it will be free on the bottom."
Super DYI!
Have 2000 2.7 base, short sockets w/philips and torx bits and ramps. Before I start, how can I tell if I can do job the easier way referred to above? I checked my BENTLEY Boxster 1997 thru 2004 service manual, it only detailed the whole 9 yard route. Thanks for any info and have a great NEW YEAR!
jotoole is offline   Reply With Quote
