Old 12-27-2008, 09:17 AM   #1
Jaxonalden
Jaxonalden's Avatar
I had the same problem and swapped out the drivers door lock assembly. I did some investigating and found the micro-switch that works the window drop with the door handle. The switch is below the lock and upside down and I found that the switch (with a plastic plunger) was dirty and didn't have any lube on it and was worn to a point that it didn't operated the micro-switch.
I'm now going to keep the mechanism clean and lithium grease applied to those contact points.
