Thread: Battery choices
Old 12-18-2008, 12:51 PM   #11
edevlin
edevlin's Avatar
"As you point out yourself, the battery is ~12V, while the alternator produces ~13.6V. An accurate analogy of voltage is water pressure in a pipe. If you have two pipes connected together in a "Y" that then go to a sprinkler, and one pipe has a higher pressure than the other, which pipe will be feeding the sprinkler? The one with the highest pressure, of course! The lower pressure pipe will in fact reverse it's flow until the pressure equalizes, which is how the battery charges!"
So, based on your discussion, if I wanted to provide more current to my outboard audio amps which are wired directly to the to the battery) the best strategy would be:
1. Get a higher output alternator
2. Get a larger battery
3. Stick a large cap in the circuit from the battery to the amps
I am especially curious about the third case. My current setup seems to be working fine, but when I had a smaller battery (11 lb Braille) in the car, when I was driving with the headlights on and the music playing loud, you could see the dash lights dim in rhythm to the music at high (very) high volume levels. With my current 15lb Braille battery everything seems to be working fine, but I am still curious about a large cap in the circuit.
Ed
:dance:
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
