Old 12-18-2008, 02:37 AM   #4
bmussatti
Guest
Posts: n/a
Originally Posted by litteng
yes it has 5w40 mobil1 but some heat in the cooling systems makes it so much easier to spin over...
You should change to 0W40 as soon as possible. You will not have any starting issues with a good battery, and properly maintained car. In the extreme cold, start it, let it idle about 90 seconds, and then start driving to properly warm-up.
Don't let it sit and idle for 10 minutes (for example), to "warm-up".
Keep RPM's below 4,000 until full op temp is reached. Shifting will be stiff (manual tranny).
Check your tire pressures at those low-low temps too.
