Thread: Battery choices
Old 12-15-2008, 09:09 AM   #3
Frodo
"Optima all the way." Posted by ekam.
Question: Did you have to pick up one of the mounting plates to install? The one in the mike.focke battery discussion site was through an outfit called Yellow Dog Motorsports. It's aluminum and runs $50. I believe I read somewhere that there's a hard plastic one for cheaper, but I haven't been able to locate it yet.
"The 15 lb Braille works fine both starting the car and driving the outboard amps. The coldest starts I have had have been in the low 20's and it pops right over. I would think if you got their 17 lb battery, which they rate for winter use, you would do fine and save a few lbs. If you are interested in saving weight for your car, it is one of the very cheapest ways to go."
Posted by edevlin.
Question: Sounds tempting, Ed, but with the shorter warranty, do you think you'll be replacing yours every 2-3 years or so? Was installation simple, requiring any adapter? Where'd you get yours?
Frodo is online now   Reply With Quote
