Just a shot in the dark, did you replace the throw out bearing as well? Regarding the metal to metal squeal, does it accelerate pace with engine RPM? If so, then it sounds like a problem back in the clutch flywheel assembly. Does the clutch perform flawlessly? Another thing to check might be all the pulleys, tensioners, ac pump maybe one of those items is making the noise, good luck.
