you seens to be a very knowledgeable person. I will be very apprecieated if you can give me some more infos on putting on DRLs on my boxster, as the parts department at my local porsche dealer won't open until monday. yes my boxster is a US spec. I was thinking if it'll be cheaper to install 2 fog lamps inside the front grills and wire it to the low beam so they are always on except when the low beams are turned on. I've heard people doing that in the NSX forums. thanks alot.
