Old 12-03-2008, 09:42 AM   #12
ekam
Originally Posted by Topless
$25k is full pop retail with all new everything from RUF or FVD. Both excellent companies. Many used 3.4, 3.6 and 3.8 conversions have been done for a lot less. Tholyoak could probably give you an exact quote as he has done 1/2 dozen of them in his garage and solved many of the conversion issues regarding engine mounts, fuel rails, intake, headers, ecu tuning etc.
I specifically said 3.8 because you will not be able to get your 986 ECU to work with the 987 motor with variocam plus. Parts for 3.4 swap are readily available.
Tell me, where are you going to get an exhaust that has the correct size piping for the 3.8? You have to get one fabricated and that means $.
I bet someone here is going to say 997 exhaust drops right in.
