Originally Posted by Kirk
Yup, sounds like a slipping clutch. How many miles do you have on the current clutch? The link to Pelican Parts is good. You can get the pressure plate, clutch, and throw out bearing as a kit for about $400. You can simply check the flywheel to see if it's within the serviceable limit, which it probably is. There's no issue really with keeping it as long as it's clean. If not and there's enough material left, get it resurfaced. The replacement for my S at Pelican is $670. It can't hurt to change it, but if it's good, then why throw the money away?
Kirk
IMO because if it takes a dump before the next clutch is worn out, or chatters upon reassembly, you have to spend all that money again to get back at it, way cheaper to eat the 600 clams up front. Once a dealer did the belts on my 944, when I got it back it was leaking like the Exxon valdeez. They had ruined the seal doing the repair, when I asked why they didn't replace it they said, you didn't ask us to. Well yeah true enough but at that time I didn't know the propensity of the seal to be damaged and they did but never suggested replacement. They replaced the seal and charged me for the complete job, no responsibility taken for their F^&kup, now their out of business, sweet karma sweet karma..
