Old 11-12-2008, 06:08 AM   #4
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Perfectlap
Cool, that sounds simple enough.
does the light go out by itself?
Yes, once you refill the washer fluid in the tank, the light will go off by itself.
Oh, and to make it easier to access the washer tank, if you have a jack, jack up the driver's side front, so that the wheel is out of the way. That will give you more room to undo the plastic rivet and nuts holding the back part of the wheel well liner in. You don't have to remove the entire wheel well liner... just undo the rear part of it so that you can slide out the rear portion. That will allow you to fully access the underside of the fender where you'll clearly see the washer tank and the hose that should lead to it.
