Old 04-06-2005, 06:35 PM   #12
Lux
An M3 cab is the worst of all worlds. It's a pig at what?...3800 lbs for the E46 and 3500 lbs for the E36? Handling will suffer as well as straight line speed.
The Boxster with its 2 trunks is actually damn practical.
If I had to pick a BMW roadster, I'd go with the Z4 before even the MZ3. At least the Z4's chassis is up to the task of being a roadster. The Z3 is a little loosey goosey.
Rowag,
You are correct on the suspension. Not that the E36 rear was that great. I've blown out more shock mounts and lower control arm bushings than the law allows. It was great when everything worked though.
Lux is offline   Reply With Quote
