[QUOTE=Jaxonalden]Why is it assumed that I can't afford a mechanical fix if this happens? You guys that argue the point if there is a failure you'll just throw money at the problem and everything will be fine. How about helping out your fellow boxster owners and figure out a fix that doesn't cost us money that we don't need to spend?
QUOTE]
The way I see it, if you've still got your Porsche and you know that if the engine goes you're most likely stuck with the bill, you're bent over just as far as the rest of us.
