Old 10-30-2008, 01:27 PM   #1
kabel
Hmm, I'm no expert, but it sounds like it could be two separate issues. I seem to recall there being an issue with faulty coolant tank caps, that could be causing that leak.
Now this is a wild speculation on my part... the only possibility I can conceive of regarding the oil line damage as a result of the water pump failing is if the water pump seized and subsequently broke the belt which they may have hit the oil line.
In addition to Redbone, there is an independent garage I use named Zotz over here in Winter Park (Near 436 and Howelbranch), the garage is literally behind the Original mattress factory on 436. There is also Troysport off SilverStar west of OBT.
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
