			when the car is started for the first time on a day it is good to let it idle for mebbe 5 minutes. In doing this it allows to heat up and lubricate the parts properly. Then drive off taking it easy until the temperature comes up. When driving straight form a cold engine, taking it easy will reduce damage but warming it up a little bit own't hurt. The most damage to an engine is during start up - and that is because the oil does not sufficiently lubricate right away. Hence the invention of oils such as Castrol Magnetic which claims to "stick" to parts to avoid this initial wear.
