Originally Posted by n4ally2
hi jbkauai,
You should actually get 4 keys. 2 that have the remote built in, 1 valet key and 1 plastic key. I am not sure if you purchased it from an original owner. If you are, I would asked them if they have any maintenance records. You should do a car fax, just to ensure there was no accidents on the car. If you can get the window sticker (the sheet on a new car windshield that tells you all the options, MPG, etc.) from the owner, get it.
Check for the wheel lock (in the front trunk).
Good luck.
Hmm... not sure about that. I only got two standard keys and the little plastic one. No specialized valet key. If they added that after 2005, well, you guys are lucky!
The manual case should include the stereo manual (nav system if you got it), owner's manual, maintenance manual, warranty manual, etc.
The toolkit should have a full container of fix-a-flat in it along with an air pump, among the other vitals.
I also got a little Porsche Roadside Assistance card with my car, not sure if that's transferrable.
