Old 10-20-2008, 07:01 PM   #1
cas951
Since you still have battery power it's probably normal drain. I suggest you have the car jump started asap and take it somewhere where you can fully charge the battery. If the battery dies comepletely you may not be able to open the trunk unless you have a trickle charger that plugs into the Cig socket.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
