Old 10-18-2008, 07:26 PM   #2
986FortyEight
Originally Posted by Sputter
Sounds like you didn't snug a coil pack enough or too much and cracked one.
Re-check em, if you read the code you could determine which one(s).
Bad or missing O ring on the tube? Maybe you fouled a plug installing it with all that oil you've described?
Thanks Sputter! I will check all coil packs again tomorrow.
I'm not sure I could have fouled the plug since I cleaned all the oil I could get prior to de-installing the old one and placing the new one in, but I will also check while I'm at it!
I am not sure about what O-ring you mention...
Michael
http://imgur.com/aiZcIk8
986FortyEight is offline   Reply With Quote
