Old 10-14-2008, 02:39 PM   #1
chaudanova
Originally Posted by 986Porsche986
I have read that if you install an engine-back exhaust you should disconnect the battery for 30 minutes to allow the the computer to adjust to the new system. Should I also do the same for just an install of a catback muffler? Its a Topspeed on a 2002 S.
Thanks in advanced.
Yes, pretty much any mods you make, inake/exhaust/engine-wise, you should reset the ECU in this way, and allow the computer to adjust to the new airflow. Drive it hard, and it will adapt to a more aggressive driving style. I've also noticed these cars are very temperature sensitive, so driving during the cold (usually at night time here compared to in the day time when it is hot out) makes a pretty notable difference in how fast the car performs/feels.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
