Old 10-14-2008, 11:56 AM   #2
chaudanova
Hey DJ, check out this thread that MTS just made:
http://986forum.com/forums/showthread.php?t=18467
The notable part was:
"I did with and without dyno runs with the Fabspeed 2nd cat bypass pipes. The car is a 2004 Boxster S Special Edition with 17k miles (de-snorkled). The baseline runs showed 228 whp. With the bypass pipes installed, the dyno showed 237 whp with a negligible/no change in hp curve. Given all the slight variations run to run, etc, I'd say the Fabspeed claim of 8 hp for using the pipes appears to be accurate, at least on my car."
He gained 9whp on the dyno... not too shabby!
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
