Old 10-09-2008, 09:09 AM   #5
bmx672
Okay, here's the deal... I switched the fuse... but I did not do the test beforehand where you listen for the click when pushing in the gas filler neck cap. So I do not know if it clicked or not with the old fuse. I should have done that first to see if the fuse was the problem.
I did have a "spirited" drive to the gas station and was able to pump gas without a problem!!! But I do not know if that's because of the fuse or the "spirited" drive.
I think later at home I'll put the old fuse back in and see if I get the clicking sound... if so then I guess it was the drive that did it! If not then it was indeed the fuse. Either way I'll be able to get home now!!!
Thanks for the help... I'll post if it was the fuse or not when I can get to it.
bmx672 is offline   Reply With Quote
