Thread: Kirk's Ride...
Old 10-07-2008, 11:03 PM   #32
Kirk
GT3 Sway Bar
One more mod this last weekend. As long as I had the front of the car jacked up and both shocks out to re-shim them, I thought it would be a good time to install my latest trick mod. It's an OEM front anti-sway bar from a Porsche 996 GT3. This is the preferred sway bar for Boxsters as it's much beefier than stock and is 5-way adjustable. The only problem is that you have to use aftermarket sway bar links to fit it and adjust for the different hole positions on the bar.
Here's the GT3 bar compared to stock. Stock is on top and is a little under 24 mm in diameter. The GT3 bar is on the bottom and is 27 mm.
Here you can see the adjustment holes on the GT3 bar compared to stock.
Here's the new end link (bottom), which is adjustable, compared to stock (top). Think it will be a bit stronger?
Here are a couple photos of it installed, not much to see really. I've got it on the softest setting for now to limit understeer until I get a spare $450 to buy the Tarett aftermarket adjustable sway bar to go in the rear. I may actually stiffen it up a bit for more understeer as I got the car sideways today on the street with snap oversteer and it's pretty abrupt (although I was doing a heroic move at the time, so it wasn't a total surprise). I may want a little more understeer for now until I get used to the new suspension and then dial it back more towards neutral once I get a rear bar.
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
