Thread: Squeaking Top
Old 10-01-2008, 12:35 PM   #1
CA_Boxster
If I understand the offending parts correctly, you might also be able to adjust where the clamshell stops when it closes on the fabric. There is a sliding adjuster on each side and you can make it stop a notch higher to put less pressure on the convertible top material.
CA_Boxster is offline   Reply With Quote
