Old 09-26-2008, 05:32 PM   #3
tolum
tolum's Avatar
Originally Posted by Tool Pants
You do not need a code to turn on the OBC, just a PST2.
I went by my local dealer and talked to the service and parts guys that I have known for years. They will not give out codes to a customer.
You should ask to see if you get a different answer.
My local dealer will code a key that the customer brings in. $85. When I had a key coded there about 8 years ago it was $50.
I got the following codes for my car this afternoon:
DME code
Remote control code 1
Remote control code 2
Ignition lock alarm code
Transpondeur code 1
Transpondeur code 2
Transpondeur code 3
Is this necessary to code a key?
2003 Boxster base
Upgrades so far: 4 Stalks installed,OBC, Cruise Control, Variable wipers, Rear speakers, Alpine CDEHD149BT deck, Alpine MRP-F250 4 ch. amplifier, Blaupunkt THb 200A pre-amplified subwoofer, XM radio integration, 997 shifter, front motor mount, LN Engineering IMS upgrade and much more.
tolum is offline   Reply With Quote
