Old 09-25-2008, 11:22 PM   #18
Lil bastard
Lil bastard's Avatar
Originally Posted by 23109VC
how many of you guys replace the caliper bolts when you do brakes???
i've done brakes on a lot of cars and never replaced this stuff... is this just BS to sell parts or do they really stretch/wear?
They really stretch. The large amount of torque spec'd - 63 Ft. Lbs. is fairly close to the limit of the Fastener material's elasticity. Replacing them is more a precautionary note, but still, it is possible they could fail if reused. It doesn't happen very often at all so reusing them at least once isn't that big a deal.
Reusing them repeatedly could cause an issue, but it's more likely the fastener, especially if slightly corroded, would break when trying to remove it rather than failing in use, though that too is possible. Then you're drilling and tapping or using an insert. The likelyhood of failure in a reused bolt is higher than one used only once.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
