Old 09-24-2008, 07:10 PM   #14
Lordblood
Originally Posted by Hops
Lordblood,
Could you describe the parts you are using (and where they are available) and how you are mounting them?
I find the stock mirrors to be nearly worthless. If I am 90+% sure there is no one in my blind spot I usually rock my head left and right a few inches to scan more and less angle off the mirror. If I am not 90% sure the blind spot is open I actually turn around and look, which of course can cause an entirely different safety issue. Top down seems to be the only way to get a really good rear view.
If you walk into any car store (Auto Zone, Checkers, etc) and walk up to the wall near the register, there are usually little things you can get under 5 dollars.
I found stick on convex mirrors, about 2 dollars a pop. They simply have an adhesive side on the back, which you stick on the ends of your regular rear view mirrors.
It increased visibility greatly, much more then the useless stock mirrors that come with.
Lordblood is offline   Reply With Quote
