Old 09-22-2008, 04:26 PM   #13
23109VC
no need for bling.
I just want OEM stuff. I"ll probably order OEM rotors from pelican.
I did a quick check on tirerack, because I'm also buying new tires, and noticed I can get rotors/pads from them. They sell Brembo rotors for about what OEM rotors cost.
Brembo is a big name brand, but is it as good as OEM? better?
I'll probably skip any cross drilled/slotted stuff and jsut get regular rotors.
I have seen the posts here saying I *can* put 987 pads/rotors on the FRONT. are they any lighter than stock? the only benefit I can see to going with them would be if they were ligthter.... if they are bigger it's probably more weight and I don't think I need/want that.
any recommendations on pads for street use?
23109VC is offline   Reply With Quote
