Old 09-18-2008, 09:06 PM   #1
shaman1204
Originally Posted by j.fro
Do it yourself...it's an easy job. Search around and you'll find complete instructions along with photos. Here's one suggestion: buy a Motive Power Bleeder and change the fluid. ATE blue is a good choice. If you are interested in a firmer pedal feel, stainless steel brake lines make a big difference, and they're an easy swap while you are doing the rest of the brake work.
I agree totally. I changed the pads and flushed the brakes on my 01 base and I've never even witnessed a brake job before. I went with Mintex redbox and ordered the Motive power bleeder, brake fluid and pads from Pelican. Not a bad price and got free shipping on the whole deal. Just make sure before you order the brake fluid you check the master cylinder to see what color fluid your are currently using and buy the opposite or you won't be able to tell when the old stuff is flushed out. IIRC the rotors aren't that difficult either, but I didn't have to do mine because they only had 35k on them. Just read and re-read the instructions before proceeding and you'll do fine. Took me a total of 3 hours for all four corners.
shaman1204 is offline   Reply With Quote
