Thread: Shift Light
Old 09-11-2008, 05:27 AM   #1
pinzgo
Send a message via MSN to pinzgo
shift light
I have Boxster s year 2000 with 6 psi supercharger, intercooler and methanol injection. Last drag, i made 12.7 with 107 mph. Huge experience. To do so I had to add shift light to help me keeping concentrate on the road. I removed cluster from dash board and unplugged RPM. It is a long white plug. If I remember, the rpm signal is the second lower pin. Anyway, just take voltmeter on 12 volts mode, put black on ground, start engine and search pin that send signal by playing with pedal. After that, just plug your remote RPM with shift light. If you have separate shift light, just stick it in front of you on the dash. I set mine at 6200. I saved close to 1 second on performance
Bests
Jacques
pinzgo is offline   Reply With Quote
