Originally Posted by Burg Boxster
LB
Rec'd the email. Wow - quite a comprehensive file w/ all the drain diagrams! I haven't seen one so complete. Did you put it together?
If so, quite impressive!
Question... If I'm reading it correctly, the diagram shows only one drain (#4) for the AC/evap. Where are the others?
Thanks!
Can't atke credit for it, it's a compilation from the factory repair manual. If you look at #3 from the Water Drainage Plan, it too serves the ac/evaporator. Probably not as critical as #4, but still if it allows water to collect, there's your mildew problem.
