Old 08-25-2008, 09:29 AM   #3
Bobiam
Bobiam's Avatar
Originally Posted by insite
it sounds like uncommanded relay engagement. you probably have part of the HID unit hooked up to something that draws current through the pulldown coil of the spoiler relay. once sufficient current flows through the coil, the e-mag force is enough to trigger the relay.
who hooked up the HID kit? was it a direct plug-in, or is it wired into the fuse panel somehow? what other aftermarket equipment do you have?
I did the HID install last winter. Direct plug-in type. No other aftermarket electrical stuff. Right after installing I had the idiot light problem. The vendor said that he should have provided some in-line capacitors for the HID being that this is a Porsche, so he sent them, I installed, but no change. But the somehow related thump thing just started last week.
I like the sound of your suspician, but don't understand it too well yet.
Bob
Bobiam is offline   Reply With Quote
