Old 08-23-2008, 12:55 PM   #3
Lordblood
Originally Posted by kabel
Where on the car did the liquid come from?
Is the temp gauge still reading normal cooing level?
Maybe the system burped itself and let out a little overflow?
The liquid is right under the engine on the right side, right under where you put in the oil and coolant.
I just started the car up and let it run a little bit, engine heat is still normal. I'm hoping it was just a little overflow, as I did just put in coolant.
Lordblood is offline   Reply With Quote
