Thread: Ticking sound
Old 08-19-2008, 01:59 PM   #5
insite
FTD -
the cloud of smoke is a non-issue, even after a couple of hours. because the motor is 'flat', it is possible for it to turn off in a position where oil can enter the cumbustion chamber.
as for the ticking, this is not uncommon under certain conditions. if you drive at a constant 3k - 4k RPMs for a few minutes, it should go away. if it doesn't, it's possible you have a sticky lifter. this can be cured with certain oil additives.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
