Old 03-23-2005, 08:05 PM   #18
jerhofer
Originally Posted by wombat7
That's interesting about the mid rear setup... I've always heard that mid rear cars were very prone to snap oversteer... is that true with Boxsters? I just got done riding with my friend in his S2K and the oversteer in it was crazy. I mean he is a very good driver, and definately drives at the edge 85 - 90 % of the time so he probably induces more than what I would usually get on the street. I dunno which car I like better... I haven't driven a Boxster yet, but we'll see what happens when I get to actually drive one. The S2K has an amazing sports car feel... very stiff, very responsive, but i dunno about having to drive it at such high RPMs....
My S2K tended to oversteer as well, but, it would not snap around as quickly as my Boxster. That is probably to be expected as it would be more common for a mid or rear engine car to have oversteering issues. I also agree about the ride quality of the S2K. The Boxster is much better and, when cruising for long distances on interstates with the top up, the Boxster is much quieter.
That being said, approaching that snap oversteer point is at a pretty high threshold. The good thing about some oversteer for autocrossing and track events is that turn-in is better and it is easier to rotate the car. As you acquire more seat time to gather confidence in either a Boxster or a 911, it becomes easier to use these characteristics to your advantage. Another advantage of mid or rear engine designs is better braking, as you have more weight over the rear wheels to make them work harder.
As for one of the remarks about getting a E36 M3, they are great cars as well. I have had both a E36 and a E46 M3. While the E46 is more refined and has more horsepower, the E36 was also great fun. Either one would be more like driving your 944 as the weight distribution in near 50-50 like the 944.
Another option would be a 968, although I am not wild about this car in the convertible configuration. If you are thinking of really concentrating on autocrossing, the rigidity of a coupe would be advantageous.
If you have the opportunity before you move to Florida, you should try a track event. You may not go back to autocrossing. You have a wonderful track less than an hour away in Putnam Park. It is very challenging yet has a long enough straightaway to gather up some serious speed. I ran my 83' 944 there many times and it was perfectly suited for this track. What you lose on the straights, you can make up in the corners against a lot of cars.
2005 Boxster
Bose
Seal Gray/Dark Gray
18" Wheels
jerhofer is offline   Reply With Quote
