Old 08-14-2008, 02:24 PM   #10
pauljsgreen
Originally Posted by AUDIOGUY
Next time you lower your top, check the center of the windshield pillar where the
latch is. At the point where the hook catches, there is a button that engages the
windows. With the top down, put your finger where the latch would normally go.
If you push the button, the windows should go up... if they dont , then you probably have a bad switch.
Just a thought.
Best of luck!
thanks for all the replies.
nothing happens when i wiggle the micro switch in the little bug eye panel at the top of the windscreen.
i need to sort the antenna grounding issue up there so i'll take the switch out at that point and have a look.
both cars were 2000 "S" - only difference is mine is a tip with pcm and the other is manual without!
BTW, my windows drop about 4 inches when i unhook the top.
i have applied the top hack to bypass the speed and parking brake checks, but it was definitely acting like that prior to the mod.
cheers
paul
pauljsgreen is offline   Reply With Quote
