Old 08-05-2008, 08:12 AM   #10
OldBlevins
Originally Posted by tolum
Forget it, I'm on my way for a new OEM battery. I have an electronic volt meter & an amp reader that I normally use for AC. Is there any way I can use my amp reader on the main positive wire that is plug on the battery to look if there is current drawned out of the battery by something in the car? If not, is there another way to see it?
Tks!
Ordinarily the way to check for a drain on the battery is to make sure everything in the car is turned off, disconnect the negative wire clamp from the battery, and put a tester between the clamp and the negative battery post. If there's no draw on the battery, no current will show up.
BUT... make sure you have your Radio Code (if your radio has one). Also, it takes awhile for the Boxster to turn everything off and I'm not as familiar as others in this forum with that element of this test.
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
OldBlevins is offline   Reply With Quote
