Old 07-31-2008, 04:32 PM   #10
fragdude
I checked the '07 manual and your car has H7 low beams, so hopefully you bought the right one!
The projector "part" of the head lamp does direct the beam pattern, so if you put a xenon bulb in there I think is should look like a regular xenon head light. One thing I would check out is bulb clearance though. The xenon bulb is a bit longer than the H7 halogen.
And you will most likely have to drill through the rear cover of the headlamp assembly. And it might be smart if you start looking for possible places to mount your ballasts (want them to be dry).
If you want pics of my install and I will gladly take some.
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
fragdude is offline   Reply With Quote
