Old 07-31-2008, 03:17 PM   #10
insite
Originally Posted by JackG
Well, my first time was without the lift I now have, and I did it the slow way without having the tool to press the tie rod end out of the wheel carrier. It was up on four jackstands, and was done like like I wrote up here:
http://986forum.com/forums/showthread.php?=4961&highlight=boot+replacement
But 3 hours? I bet I worked on each CV joint 30 minutes just to get them perfectly cleaned and greased back up. That's two hours right there.
you pressed out the tie rod ends? what else did you do? agreed that you can spend a lot of time obsessing over cleanliness best not to use any cleaning agents inside the joint unless you clean everything w/ alcohol afterward. simply wipe out the excess grease w/ shop towels & re-grease on reassembly.
FYI, i DO have air tools, which help, but i DO use hand tools much of the time.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
