Old 07-30-2008, 04:03 PM   #1
Sboxin
Is the pedal very hard to press to engage the clutch?
This is the first sign of a worn clutch disk.
If you had a new clutch at 22K you should not need one this soon.
Have you flushed or blead the clutch system?
This may help with the pedal 'feel'.
If you wait for the clutch to actually slip then you are too late to save the flywheel because the rivets will be into the flywheel causing the slipping.
I would bleed the brakes and clutch and see what changes.
Take care,
Ed
Sboxin is offline   Reply With Quote
