Old 07-29-2008, 03:55 AM   #11
John V
Originally Posted by djmunsey
Thanks for the info John. Turns out it takes 2 to 3 weeks for him to convert the struts. I am sure he is busy with work and he is racing weekends too. He doesn't seem too agreeable to doing them any cheaper even if he does more than 1 set. I guess I will get on with it and hope I don't end up thinking the stock M030 shocks were better than the Koni's. I pulled that GT3 front sway bar off after a full year with it on. Immediately the slaloms felt 1000% better but it does one leg it more without the GT3 bar.
Make sure he knows the weight of your car, what tire sizes you run, and tell him that you only autocross the car, no road racing. You should be all set. Are you getting doubles or singles?
If you can send me the specs when you're done (i.e. what inserts they used) that would be extremely helpful. Good luck.
John
John V is offline   Reply With Quote
