Old 07-29-2008, 01:15 AM   #13
djmunsey
RE: Boxster S struts
Originally Posted by John V
M030 and standard struts are identical in terms of outside dimensions, the only difference is the internal valving. So no, it doesn't matter for a cut and gut Koni install. Stock struts will work fine.
John
Thanks for the info John. Turns out it takes 2 to 3 weeks for him to convert the struts. I am sure he is busy with work and he is racing weekends too. He doesn't seem too agreeable to doing them any cheaper even if he does more than 1 set. I guess I will get on with it and hope I don't end up thinking the stock M030 shocks were better than the Koni's. I pulled that GT3 front sway bar off after a full year with it on. Immediately the slaloms felt 1000% better but it does one leg it more without the GT3 bar.
djmunsey is offline   Reply With Quote
