Old 07-19-2008, 02:29 PM   #1
CA_Boxster
Location of stereo wiring in dash
Does anyone know the route the wires are run through from the head unit to the dash speakers? I have a rattle in my driver's side dash that won't go away and has gotten worse over time. I've been all through it from underneath and also pulled out the gauge cluster to look behind there and everything I've suspected as the culprit and dealt with has apparently been wrong. It sounds like a loose connector or metal part is banging against another metal area. The sound gets gradually worse as the dash gets colder (i.e., when the a/c is on) and only happens over bumps or during braking. My dash speakers were replaced by a shop a long time ago and I suspect the original speaker-end connector has come loose from wherever they may have taped it off but I can't find it. It's a 2000 car.
CA_Boxster is offline   Reply With Quote
