Old 07-17-2008, 11:18 AM   #1
Quickurt
Quickurt's Avatar
Originally Posted by vipola
are you sure it's not just the steering lock because you turned it ? :P play witht he steering while turning the key..
The steering lock is quite stout in my 987. It'll lock up the whole column to the point you're not quite sure which way to turn the wheel to free it up.
Also, on the 987 the key will turn and do NOTHING if it's not inserted all the way!
Twist and twist and turn it all the way to off position and try it again, and NOTHING. Then you figure out you didn't push the key all the way in!
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
