Old 07-11-2008, 07:47 PM   #1
h20break
Originally Posted by 60drvr
your brake pads should burn off your rotors when you drive and brake normally. I live in Ohio and with the humidity and weather, my rotors will get a little rust if I havent driven my car in a week or so. Try SIMPLE GREEN! I use it to clean my old rims and it eats right through the dust that a water hose wont touch. SIMPLE GREEN is also biodegradeable if you live in Cali or have kids or dogs running around. It is the military clean all from weapons to aircraft to latrines. The stuff is pretty good and you can get it anywhere.
Thanks, I'll try it. I think you are right about the humidity because my rotors have not done this before, but now the humidity is a lot higher and I only drive my car once a week at most.
h20break is offline   Reply With Quote
