Old 07-07-2008, 03:58 PM   #1
AUDIOGUY
I would certainly remove the entire assembly and re-install it. I had this happen with my Litronics and the connection was bad. Make sure the harness is plugged into the housing. This should fix it. If you have checked the obvious, fuses, relays, etc.
Good luck!
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
